man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
fmtmsg.h(3HEAD)
Name
fmtmsg.h, fmtmsg - message display structures
Synopsis
#include <fmtmsg.h>
Description
The <fmtmsg.h> header defines the following macros, which expand to constant integer expressions:
MM_HARD
Source of the condition is hardware.
MM_SOFT
Source of the condition is software.
MM_FIRM
Source of the condition is firmware.
MM_APPL
Condition detected by application.
MM_UTIL
Condition detected by utility.
MM_OPSYS
Condition detected by operating system.
MM_RECOVER
Recoverable error.
MM_NRECOV
Non-recoverable error.
MM_HALT
Error causing application to halt.
MM_ERROR
Application has encountered a non-fatal fault.
MM_WARNING
Application has detected unusual non-error condition.
MM_INFO
Informative message.
MM_NOSEV
No severity level provided for the message.
MM_PRINT
Display message on standard error.
MM_CONSOLE
Display message on system console.
The table below indicates the null values and identifiers for fmtmsg(3C) arguments. The <fmtmsg.h> header defines the macros in the Identifier column, which expand to constant expressions that expand to expressions of the type indicated in the Type column:
Argument
Type
Null-Value
Identifier
label
char*
(char*) NULL
MM_NULLLBL
severity
int
0
MM_NULLSEV
class
long
0L
MM_NULLMC
text
char*
(char*) NULL
MM_NULLTXT
action
char*
(char*) NULL
MM_NULLACT
tag
char*
(char*) NULL
MM_NULLTAG
The <fmtmsg.h> header also defines the following macros for use as return values for fmtmsg():
MM_OK
The function succeeded.
MM_NOTOK
The function failed completely.
MM_NOMSG
The function was unable to generate a message on standard error, but otherwise succeeded.
MM_NOCON
The function was unable to generate a console message, but otherwise succeeded.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
fmtmsg(3C), attributes(5), standards(5)
