Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Windows Operating System |
Part I Windows Server Installations
1. Assisted OS Installation With Oracle Hardware Installation Assistant
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3. Installing Windows Server 2008
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4. Post Installation of Windows Server 2008
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
5. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Windows Server System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D. Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
You can perform the following tasks using Oracle Hardware Installation Assistant:
Note - The supported Oracle Hardware Installation Assistant installation and recovery tasks listed below are server-dependent and might vary.
Perform an assisted installation of a Linux or Windows operating system on your Sun x86 server from Oracle. Oracle Hardware Installation Assistant provides the appropriate drivers and platform-specific software, eliminating the need to create a separate driver disk.
Optionally create RAID-0 or RAID-1 volumes on internal storage devices.
Optionally upgrade your system's Oracle Integrated Lights Out Manager (ILOM) service processor (SP), BIOS, and storage device firmware (regardless of the OS on your server).
Optionally update your Oracle Hardware Installation Assistant session with the latest firmware and drivers.
Optionally recover from a corrupt or inaccessible Oracle ILOM service processor.
