Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Windows Operating System
search filter icon
search icon
Document Information
Using This Documentation
Part I  Windows Server Installations
1.  Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
2.  Getting Started
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3.  Installing Windows Server 2008
Before You Begin
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4.  Post Installation of Windows Server 2008
Before You Begin
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
Configuring Support for TPM
Configuring Intel NIC Teaming
5.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Windows Server System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
Before You Begin
View or Edit BIOS Settings for New Installations
D.  Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Getting Started
Procedures for Incorporating Drivers Into WIM Image(s)
In the BIOS Setup Utility, you can set optimal defaults, as well as view and edit BIOS settings as needed. Any changes you make in the BIOS Setup Utility (by pressing F2) are permanent until the next time you change them.
In addition to using the F2 key to view or edit the system's BIOS settings, you can use F8 during the BIOS start-up to specify a temporary boot device. If you use F8 to set a temporary boot device, this change is only in effect for the current system boot. The permanent boot device specified through F2 will be in effect after booting from the temporary boot device.
Before You Begin
Ensure that the following requirements are met prior to accessing the BIOS Setup Utility.
