Resolved Issues
This section describes resolved issues on the Sun Server X3-2L.
For the latest information about resolved issues on the Sun Server X3-2L, refer to the updated product notes, which are available at the following web site:
https://www.oracle.com/goto/x3-2l/docs
Note -
The resolved issues table lists the issues by the Bug ID number (the identification number assigned by the current Oracle BugDB bug tracking system) and the Change Request number (the identification number assigned by the previous bug tracking system). Either number, the Bug ID number or the CR number, can be used to access the issue in BugDB.
Documentation implies ability to set RAID volume as global hot spare
fmtopo output incorrect in single-processor systems (15812479, formerly CR 7194345)
Power-on command might not work after rapid power off/on cycles (15775215, formerly CR 7148627)
Attempts to change serial port ownership in BIOS Setup Utility fails (15791123, formerly CR 7168093)
Event logged for power reset is incorrect (15788495, formerly CR 7165042)
Ethernet ports NET 2 and NET 3, and PCIe slot 1 are incorrectly displayed as editable in the BIOS IO Menu screen (15800659, formerly CR 7179910)
Server's network interface controllers cannot establish 100 Mb link in UEFI BIOS mode (15766055, formerly CR 7129556)
The IPMItool boot override command overrides existing boot priority list (15774974, formerly CR 7148294)
BIOS bootlist might permanently change when IPMItool is used to override the existing bootlist (15774795, formerly CR 7148056)
Message "cannot retrieve host power status" appears in Oracle ILOM web interface when launching Oracle System Assistant (15763811, formerly CR 7126194)
Oracle System Assistant does not support creating, deleting, or modifying the username "user" (15777542, formerly CR 7151906)
Fibre channel adapters not supported in UEFI boot mode (15776345, formerly CR 7150235)
Oracle ILOM might not support the clearing of faults diagnosed by the Oracle Solaris operating system (15793363, formerly CR 7170842)
No USB controller in fmtopo for servers, and fault.sunos.eft.unexpected_telemetry is reported (15773526, formerly CR 7146324)
Oracle Solaris operating system panics during a system power off or a system reboot (15829089)
Oracle ILOM Hard Cap power setting does not work with Oracle Solaris operating systems (15786729, formerly CR 7162900)
Oracle Solaris 11.1 operating system installation process might fail (15805238)
Xorg GUI might fail to start with Oracle Solaris 11 11/11 (15755307, formerly CR 7112301)
Related Information
