Go to main content
Sun Server X3-2L (formerly Sun Fire X4270 M3) Product Notes Version 1.6
Exit Print View
Updated: January 2017
Oracle Solaris 10 8/11 Required Patches
Before installing Oracle Solaris 10 8/11 on the server, you should install the patches listed in the following table.
Table 1  Required Patches for Oracle Solaris 10 8/11
Required Patches
CRs Fixed
CR Descriptions
148170-02
7097919
Ethernet issue. This patch fixes an issue with Ethernet (ixgbe) ports losing link. Note that this issue also affects Oracle Solaris JumpStart installations. To support JumpStart installations, apply this patch to your Solaris 10 8/11 JumpStart miniroot image. The instructions for patching miniroot are in the Oracle Solaris 10 8/11 Installation Guide: Network Based Installations at: http://docs.oracle.com/cd/E23823_01/html/E23800/netinstall-patch.html.
147706-02
6986256
FMA support. This patch adds support for Oracle Solaris Fault Management Architecture (FMA) for the Intel CPU used in the Sun Server X3-2L.
148172-01
6893274
Kernel issue. This patch fixes a problem with delayed visibility to processor threads that can cause a panic that contains the string turnstile_block and unowned mutex.
147441-08
7001739
AVX issue. This patch fixes an issue with Intel AVX support.
147156-01
6956660
Processor performance counters support. This patch adds performance counter support for the Intel processor used in the Sun Server X3-2L.
147150-01
7052663
HBA issue. This patch fixes a panic that can occur when booting from an SGX-SAS6-INT-Z host bus adapter (HBA).
148099-03
7026372
SCSI issue. This patch fixes an issue with SCSI DMA transfers during cable disconnects that reports "Error setting up next portion of DMA transfer."
