Skip Navigation Links
Exit Print View
Sun Server X3-2L (formerly Sun Fire X4270 M3)
Product Notes, Version 1.2
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Support and Accessibility
Sun Server X3-2L Product Notes
Sun Server X3-2L Name Change
Supported Hardware
Supported Firmware Revisions
Supported Operating Systems
Important Operating Notes
Single-Processor to Dual-Processor Upgrade Is Not Supported
Update Your System to the Latest Software Release
Avoid Overwriting the Embedded Oracle System Assistant USB Flash Drive
Oracle Solaris 10 8/11 Required Patches
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Supported Operating System Limitations
Update HBA Firmware to Support UEFI BIOS
Segfaults Might Occur on Servers Running 64-bit Linux Operating Systems
Failure of a Single Server Fan Module Might Impact Performance
MAC Address Mapping to Ethernet Ports
Rear-Mounted HDD Naming When Using Oracle Solaris
Inspect Grounding Strap on 3.5-inch HDD Bracket Before Installing HDDs
Battery Module
Server Management Tools
Supported PCIe Cards
Resolved Issues
Known Issues
Hardware Known Issues
Oracle System Assistant Known Issues
Oracle Solaris Operating System Known Issues
Linux Operating Systems and Virtual Machine Known Issues
Documentation Known Issues
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
This section provides information about limitations and recommendations for the supported operating systems when the Sun Server X3-2L is configured with 3-terabyte (3-TB) 7200-RPM 3.5-inch SAS hard disk drives (HDDs).
To use the following operating systems without installation or boot drive limitations on servers with the 3.5-inch SAS drive configuration, you should obtain and use a 600-Gb, 3.5-inch SAS HDD. Alternatively, if your configuration has rear 2.5-inch drives, these have a smaller capacity and you can use these for your installation and boot image.
The following table lists the operating system limitations and recommendations for 3-TB drive boot support when the system is configured with either the SGX-SAS6-INT-Z or the SGX-SAS6-R-INT-Z host bus adapter (HBA).
Table 2 Limitations and Recommendations for 3-TB Install and Boot Support
With SGX-SAS6-INT-Z HBA
With SGX-SAS6-R-INT-Z HBA
Operating System
Legacy Boot
UEFI Boot
Legacy Boot
UEFI Boot
Oracle Solaris 10
2 TB used, 1 TB unusable
Not applicable
Use virtual drive that is less than 2.19 TB
Not applicable
Oracle Solaris 11 11/11
Not applicable
Not applicable
Oracle Solaris 11.1
Not recommended
Recommended
Not recommended
Recommended
Oracle Linux 6.1, 6.2, and 6.3
RHEL 6.1, 6.2, and 6.3
Not recommended
Recommended
Not recommended
Recommended
Oracle Linux 5.7 and 5.8
RHEL 5.7 and 5.8
Not applicable
Not applicable
Not applicable
SLES 11 SP1 and SP2
Not recommended
Recommended
Not recommended
Recommended
Windows Server 2008 SP2/R2 SP1
Not applicable
Recommended
Not recommended
Recommended
Oracle VM 3.0 and 3.1
Not applicable
Not applicable
Not applicable
VMware ESXi 5.0
Not applicable
Not applicable
Not recommended
Recommended
VMware ESXi 5.0 Update 1 and ESXi 5.1
Not recommended
Recommended
Not recommended
Recommended
The following table lists limitations for the preinstalled operating systems that use 3-TB boot drives when the system is configured with either the SGX-SAS6-INT-Z or the SGX-SAS6-R-INT-Z host bus adapter (HBA).
Table 3 Preinstalled Operating System Support for 3-TB Drives
With SGX-SAS6-INT-Z HBA or SGX-SAS6-R-INT-Z HBA
Operating System
Legacy Boot
Not supported
600-GB HDD required
Oracle VM 3.x
Not supported
600-GB HDD required
The following table lists operating system support for 3-TB data drives when the system is configured with either the SGX-SAS6-INT-Z or the SGX-SAS6-R-INT HBA.
Table 4 Data Drive Support for 3-TB Drives
Operating System
3-TB Data Drive
Support for SGX-SAS6-INT-Z or SGX-SAS6-R-INT-Z HBA
Oracle Solaris 10
Patch 148099-03 required (CR 7026372)
Both HBAs supported
SRU required (CR 7026372)
Both HBAs supported
Oracle Solaris 11.1
Supported
Both HBAs supported
Supported
Both HBAs supported
RHEL 5.7 and 5.8
Supported
Both HBAs supported
SLES 11 SP1 and SP2
Supported
Both HBAs supported
Windows 2008 SP2/R2 SP1
Supported
Both HBAs supported
Supported
Both HBAs supported
VMware ESXi 5.0
Supported, but only with the SGX-SAS6-R-INT-Z HBA installed
SGX-SAS6-R-INT-Z supported only
Supported
Both HBAs supported
