Skip Navigation Links | |
Exit Print View | |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) on SPARC SuperCluster Supplement |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) for SPARC SuperCluster
Accessing Oracle Enterprise Manager Ops Center Documentation
Restrictions on SPARC SuperCluster
Discovering a SPARC SuperCluster Component
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
Oracle Enterprise Manager Ops Center is initially installed on the SPARC SuperCluster by Oracle ACS. This section describes the rules followed to install Oracle Enterprise Manager Ops Center on SPARC SuperCluster.
Oracle Enterprise Manager Ops Center should be installed on the compute node in an Oracle Solaris 11 Control Domain. If SPARC SuperCluster comes with an Oracle 11gR2 Database, it will be installed in this domain. The Control Domain on another compute node will be used for a standby Enterprise Controller should HA be configured later.
Enterprise Controllers intended to manage SPARC SuperCluster cannot be installed outside of SPARC SuperCluster.
Oracle Enterprise Manager Ops Center cannot be installed in a zone on SPARC SuperCluster.
Oracle Enterprise Manager Ops Center will be installed with co-located Proxy Controllers, which means the Proxy Controllers will be placed on the same nodes as the Enterprise Controllers, but will be configured in HA mode.
Note - In case of the current non-HA default installation there will be just one proxy controller collocated with a single Enterprise Controller.
Oracle Enterprise Manager Ops Center should use the Oracle 11gR2 Database connected to the storage servers on SPARC SuperCluster.
All SPARC SuperCluster assets are discovered during the installation process and should appear in the Oracle Enterprise Manager Ops Center user interface SuperCluster View mode.
