Skip Navigation Links | |
Exit Print View | |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) on SPARC SuperCluster Supplement |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) for SPARC SuperCluster
Accessing Oracle Enterprise Manager Ops Center Documentation
Restrictions on SPARC SuperCluster
Discovering a SPARC SuperCluster Component
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
Use this procedure to add a monitoring rule from the Asset view.
The start and end times are based on the monitored asset's time zone.
The default setting is 5 minutes. You can change the amount of time and the unit of measurement to be either minutes, hours, or days.
