Skip Navigation Links | |
Exit Print View | |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) on SPARC SuperCluster Supplement |
Oracle Enterprise Manager Ops Center 12c Release 1 (12.1) for SPARC SuperCluster
Accessing Oracle Enterprise Manager Ops Center Documentation
Discovering a SPARC SuperCluster Component
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
This section describes the restrictions when using Oracle Enterprise Manager Ops Center on SPARC SuperCluster.
At this time, you cannot update SPARC SuperCluster software and firmware through Oracle Enterprise Manager Ops Center. You must manually download and install the SPARC SuperCluster QMUs (QFSDP) to update the system.
Note - While the Oracle Enterprise Manager Ops Center allows you to update individual components, it should not be attempted as it is not supported.
Do not use Oracle Enterprise Manager Ops Center to create or modify LDoms on SPARC SuperCluster. LDom configurations are set at the initial installation of the system and any changes made to the LDom configuration could negatively affect system performance.
SPARC SuperCluster does not support use of the Oracle VM Server managment features described in the “Management of Logical Domains” section of the Oracle Enterprise Manager Ops Center Feature Reference Guide at:
http://docs.oracle.com/cd/E27363_01/doc.121/e27511/ftr_ovm_sparc_mgmt.htm#BABEAEGI
Oracle Enterprise Ops Center is not allowed to change the InfiniBand and optional 10GBE network configuration on SPARC SuperCluster.
SPARC SuperCluster does not support use of the Network managment features described in the “Networks” section of the Oracle Enterprise Manager Ops Center Feature Reference Guide at:
http://docs.oracle.com/cd/E27363_01/doc.121/e27511/network_mgmt.htm#autoId0
Oracle Enterprise Ops Center is not allowed to make modifications to the ZFS SA on SPARC SuperCluster.
SPARC SuperCluster does not support use of the managment features described in the “Storage Server: Sun ZFS Storage Appliance” section of the Oracle Enterprise Manager Ops Center Feature Reference Guide at:
http://docs.oracle.com/cd/E27363_01/doc.121/e27511/storage_mgmt.htm#autoId30
Oracle Enterprise Ops Center is not allowed to bare metal provision servers in the rack or provision their Oracle VM Server guests.
SPARC SuperCluster does not support use of the provisioning features (for bare metal servers and their Oracle VM Servers guests) described in the “Provisioning Operating Systems” section of the Oracle Enterprise Manager Ops Center Feature Reference Guide at:
http://docs.oracle.com/cd/E27363_01/doc.121/e27511/os_management.htm#autoId18
You can use Oracle Enterprise Manager Ops Center to create zones on SPARC SuperCluster.
