Go to main content
SPARC T7-2 Server Service Manual
Exit Print View
Updated: July 2019
Verify a Drive
  1. If the OS is shut down, and the drive you replaced was not the boot device, boot the OS.
    Depending on the nature of the replaced drive, you might need to perform administrative tasks to reinstall software before the server can boot. Refer to the Oracle Solaris OS administration documentation for more information.
  2. At the Oracle Solaris prompt, list all drives in the device tree, including any drives that are not configured.
    # cfgadm -al
    This command helps you identify the drive you installed.
    Ap_id             Type        Receptacle   Occupant       Condition
    c0                scsi-bus    connected    configured     unknown
    c0::dsk/c1t0d0    disk        connected    configured     unknown
    c0::sd1           disk        connected    unconfigured   unknown
    usb0/1            unknown     empty        unconfigured   ok
    usb0/2            unknown     empty        unconfigured   ok
  3. Configure the drive.
    For example, to configure the second disk c0::sd1, type:
    # cfgadm -c configure c0::sd1
    Replace c0::sd1 with the drive name for your configuration.
  4. Verify that the blue Ready to Remove LED is no longer lit on the drive that you installed.
    See Determine Which Drive Is Faulty.
  5. At the Oracle Solaris prompt, list all drives in the device tree, including any drives that are not configured.
    # cfgadm -al
    The replacement drive is now listed as configured, as shown in the following example.
    Ap_Id            Type         Receptacle   Occupant      Condition
    c0::dsk/c1t1d0   disk         connected    configured    unknown
  6. Perform one of the following tasks based on your verification results:
    • If the previous steps did not verify the drive, see Detecting and Managing Faults.
    • If the previous steps indicate that the drive is functioning properly, perform the tasks required to configure the drive. These tasks are covered in the Oracle Solaris OS administration documentation.
    For additional drive verification, you can run Oracle VTS. Refer to the Oracle VTS documentation for details. Refer to http://docs.oracle.com/cd/E19719-01/index.html.
Related Information
