Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
LA is disabled by default. See LA Topology Example for the topology of this procedure.
SEFOS# configure terminal SEFOS(config)# set port-channel enable SEFOS(config)# end
SEFOS# show etherchannel summary
The output in switch A and switch B should be:
Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:68:2f
Note - To shut down the entire LA module, type the shutdown port-channel command.
