Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
You can display a detailed report or a summary of the LACP status by using the show command. You can view specific information about the load-balancing and frame-distribution schemes, specific information about the individual ports in the port channel, and general information about the port channel settings.
