Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
  1. Enable port channeling, and create the port channel (1 in this example).
    SEFOS# configure terminal
    SEFOS(config)# set port-channel enable
    SEFOS(config)# interface port-channel 1
    SEFOS(config-if)# no shutdown
  2. Configure the port.
    SEFOS(config)# interface extreme-ethernet 0/3
  3. Configure the physical port in the port channel, and specify the mode by which the port becomes part of the port channel.
    SEFOS(config-if)# channel-group channel_group_number mode mode_value
    SEFOS(config-if)# end
    where:
    • channel_group_number can be 1 to 64. Each port channel can have up to eight compatibly configured Ethernet interfaces.
    • mode_value can be:
      • active - LACP negotiation is started unconditionally.
      • passive - LACP negotiation is started only when an LACP packet is received from the peer.
      • on - Forces the interface to be a part of the port channel without communicating through the LACP protocol. This value is equivalent to manual aggregation.
  4. Review the etherchannel information to ensure that the values for the channel group and the mode have changed in both switches.
    The following output has been truncated for readability. The output in both switches should be the same.
    SEFOS# show etherchannel 1 detail
    Port State = Up in Bundle
    Channel Group : 1
    Mode : Active
    Port-channel = Po1
  5. If the port channel interface is not present, you must create it by typing these commands.
    SEFOS(config)# interface port-channel port_number
    Note - Verify the LACP feature by enabling LACP (Active or Passive) on both actor and partner sides. If LACP is enabled on the actor side and manual on the partner side (or vice versa), LACP results in inconsistent behavior. Thus, you must avoid this misconfiguration.
