Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
In the following procedure, ports 0/1, 0/2, and 0/3 are part of the LA.
  1. On switch A, review the port state behavior for the default port identifier.
    SEFOS# show etherchannel 1 detail
    The following output has been truncated for readability.
                     LACP Port   Admin  Oper   Port    Port
    Port     State   Priority    Key    Key    Number  State
    Ex0/1    Bundle  128         1      1      0x1     0xbe
    Ex0/2    Bundle  128         1      1      0x2     0xbe
    Ex0/3    Standby 128         1      1      0x3     0xa2
    Note - Before you configure the LACP port identifier, note that the extreme-ethernet port, 0/3, in switch A and switch B are standby ports.
  2. For port 0/3 in switch A, configure the port identifier as 1.
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# lacp port-identifier 1
  3. Review the configuration information.
    The output has been truncated for readability.
    SEFOS# show etherchannel detail
    Ex0/1    Bundle  128         1      1      0x1     0xbc
    Ex0/2    Standby 128         1      1      0x2     0xa0
    Ex0/3    Bundle  128         1      1      0x3     0xbc
    Note - After you configure the LACP port identifier, note that the extreme-ethernet port, 0/3, in switch A is brought up in the bundle state.
