Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
If you change the MTU value of the port channel, the new value is applied on all of the ports in the bundle. All of the port channel member ports are bundled in switch A.
SEFOS# configure terminal SEFOS(config)# interface port-channel 1 SEFOS(config-if)# shutdown
SEFOS(config-if)# mtu 1000 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit
SEFOS(config)# interface extreme-ethernet 0/2 SEFOS(config-if)# shutdown
SEFOS# show etherchannel 1 detail
Port-channel Module Admin Status is enabled
Port-channel Module Oper Status is enabled
Port-channel System Identifier is 00:01:02:03:04:01
LACP System Priority: 32768
Channel Group Listing
Group: 1
Protocol :LACP
Ports in the Group
Port : Ex0/1
Port State = Up in Bundle
Channel Group : 1
Mode : Active
Pseudo port-channel = Po1
LACP port-priority = 128
LACP Wait-time = 2 secs
LACP Port Identifier = 1
LACP Activity : Active
LACP Timeout : Long
Aggregation State : Aggregation, Sync, Collecting, Distributing, Defaulted
Port : Ex0/2
Channel Group : 1
Mode : Active
LACP Port Identifier = 2
LACP Timeout : Long
LACP Port Admin Oper Port Port
Port State Priority Key Key Number State
Ex0/1 Bundle 128 1 1 0x1 0xbe
Ex0/2 Bundle 128 1 1 0x2 0xbe
Port-channel : Po1
Number of Ports = 2
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
MAC selection = Dynamic
