Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
The LACP time out value is a periodic interval. When the interval expires, an LACP PDU is sent out regularly. The default value for LACP time out is long. This list contains explanations of the possible values:
long - The LACP PDU will be sent for every 30 seconds, and the LACP timeout value (when no packet is received from the peer) is 90 seconds.
short - The LACP PDU will be sent every 1 second. The timeout value is 3 seconds.
SEFOS(config)# configure terminal SEFOS(config)# interface extreme-ethernet 0/1
SEFOS(config-if)# lacp timeout short
SEFOS# show etherchannel detail ... LACP Port Identifier = 1 LACP Activity : Active LACP Timeout : Short ...
