Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
In the following procedure, ports 0/1, 0/2, and 0/3 are part of the LA. Unless otherwise noted, you must run all of the commands in the following procedure on both switches.
SEFOS# configure terminal SEFOS(config)# set port-channel enable
SEFOS(config)# interface port-channel 1 SEFOS(config-if)# no shutdown SEFOS(config)# end
SEFOS(config)# lacp system-identifier 00:55:44:33:22:11 SEFOS(config)# end
The output has been truncated for readability.
SEFOS# show etherchannel detail ... Port-channel System Identifier is 00:55:44:33:22:11 ...
