Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
The LACP wait time is the interval of time the system takes to aggregate a link. Configuring the wait time value as 0 ensures that links get aggregated immediately. The default value for the LACP wait time is 2.
SEFOS(config)# configure terminal SEFOS(config)# interface extreme-ethernet 0/1
SEFOS(config-if)# lacp wait-time 1
SEFOS# show etherchannel 1 detail ... LACP port-priority = 128 LACP Wait-time = 1 secs LACP Port Identifier = 1 ...
