Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
To work with acceptable frame types, you must ensure that the follow prerequisites are met:
VLAN must be configured.
PVID for the interfaces must be configured.
Acceptable frame types must be configured.
See Default Settings for the topology for this procedure.
SEFOS# configure terminal SEFOS(config)# vlan 15 SEFOS(config-vlan)# ports extreme-ethernet 0/15,0/19 untagged extreme-ethernet 0/15,0/19 SEFOS(config-vlan)# exit SEFOS(config)# interface extreme-ethernet 0/15 SEFOS(config-if)# no shutdown SEFOS(config-if)# switchport pvid 5 SEFOS(config-if)# exit SEFOS(config)# interface extreme-ethernet 0/19 SEFOS(config-if)# no shutdown SEFOS(config-if)# switchport pvid 5 SEFOS(config-if)# end
The ping must be successful.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/15 SEFOS(config-if)# switchport acceptable-frame-type tagged SEFOS(config-vlan)# end
SEFOS# show vlan id 5 Vlan database ------------------- Vlan ID : 5 Member Ports : Ex0/15, Ex0/19 Untagged Ports : Ex0/15, Ex0/19 Forbidden Ports : None Name : Status : Permanent ------------------------------------
SEFOS# show vlan port config port extreme-ethernet 0/15 Vlan Port configuration table ------------------------------- Port Ex0/15 Port Vlan ID : 5 Port Acceptable Frame Type : Admit Only Vlan Tagged Port Ingress Filtering : Disabled Port Mode : Hybrid Port Gvrp Status : Enabled Port Gmrp Status : Enabled Port Gvrp Failed Registrations : 0 Gvrp last pdu origin : 00:00:00:00:00:00 Port Restricted Vlan Registration : Disabled Port Restricted Group Registration : Disabled Mac Based Support : Disabled Subnet Based Support : Disabled Port-and-Protocol Based Support : Enabled Default Priority : 0 Tunnel Status : Disabled Dot1x Protocol Tunnel Status : Peer LACP Protocol Tunnel Status : Peer Spanning Tree Tunnel Status : Peer GVRP Protocol Tunnel Status : Peer GMRP Protocol Tunnel Status : Peer IGMP Protocol Tunnel Status : Peer Filtering Utility Criteria : Default Port Protected Status : Disabled ----------------------------------------------------------------
After you configure the acceptable frame type as Admit OnlyVLAN Tagged, the ping from host A to host B should fail because ping(1M) packets are untagged.
