Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
The following table lists the configuration modes used in this document with their access and exit methods.
