Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
VLAN Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
VLAN Configuration
Configuration Guidelines
Default Settings
Configuring Static VLAN Entries
Create Member Ports
Create Forbidden Ports
Viewing VLAN Information
Retrieve the VLAN Summary
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Delete a VLAN
Enable VLANs
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring QinQ
Enable Tunneling on a Port
Enable STP Packet Tunneling
Configure QinQ
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configuring Port Filtering
Configure the Acceptable Frame Type
Configure Ingress Filtering
Flow-Based Configuration
Flow-Based Example Topologies
Example Topolgy 1
Example Topolgy 2
Example Topolgy 3
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configuring GVRP
Configure VGRP for Topology 1
Configure VGRP for Topology 2
Configure VLANs on the Nonroot Bridge
Configure GMRP
Classify VLANs
Create Acceptable Frame Types
Configure GMRP
To configure GMRP, you must ensure that the following prerequisites are met:
See Default Settings for the topology for this procedure.
  1. Configure the VLAN in switch 1.
    SEFOS# configure terminal
    SEFOS(config)# interface range extreme-ethernet 0/3-4
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
    SEFOS(config)# vlan 2
    SEFOS(config-vlan)# ports extreme-ethernet 0/3-4
    SEFOS(config-vlan)# exit
    SEFOS(config)# mac-address-table static multicast 01:02:03:04:05:06 vlan 2 interface extreme-ethernet 0/3
    SEFOS(config)# end
  2. Configure the VLAN in switch 2.
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# end
  3. Review the multicast group entries in switch 1.
    SEFOS# show mac-address-table static multicast
    Static Multicast Table
    Vlan           : 2
    Mac Address    : 01:02:03:04:05:06
    Receive Port   :
    Member Ports   : Ex0/3
    Status         : Permanent
    Total Mac Addresses displayed: 1
  4. Review the multicast group entries in switch 1.
    SEFOS# show mac-address table
    Vlan    Mac Address               Type     Ports
    1       00:14:4f:6c:61:d1        Learnt   Ex0/3
    1       00:1b:21:53:71:f9        Learnt   Ex0/3
    2       00:14:4f:6c:61:d1        Learnt   Ex0/3
    2       01:02:03:04:05:06        Static   Ex0/3
    Total Mac Addresses displayed: 4
