Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
In this topology, two switches are connected back-to-back using two ports on each switch. The spanning tree that is running in the switches is RSTP. Switch 2 is the root bridge in STP.
Interface P1 and P2 in switch 1 and switch 2 must be enabled.
VLAN must be configured.
See Example Topolgy 2 for the topology referenced in this procedure.
SEFOS# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:61:cf Cost 0 Port 0 [0] This bridge is the root Max Age 20 Sec, forward delay 15 Sec MST00 Spanning tree Protocol has been enabled. MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:61:cf Max age is 20 sec, forward delay is 15 sec Dynamic Path Cost is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/3 Designated Forwarding 2000 128 P2P Ex0/15 Designated Forwarding 2000 128 P2P Ex0/16 Designated Forwarding 2000 128 P2P Ex0/19 Designated Forwarding 2000 128 P2P Ex0/22 Designated Forwarding 2000 128 P2P
SEFOS# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:61:cf Cost 2000 Port 3 [Ex0/3] Max age 20 Sec, forward delay 15 Sec MST00 Spanning tree Protocol has been enabled MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Id Priority 32768 Address 00:21:28:56:d7:a9 Max age is 20 sec, forward delay is 15 sec Dynamic Path Cost is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/3 Root Forwarding 2000 128 P2P Ex0/15 Designated Forwarding 2000 128 P2P Ex0/19 Designated Forwarding 2000 128 P2P Ex0/21 Designated Forwarding 2000 128 P2P
SEFOS# configure terminal SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3 SEFOS(config-vlan)# exit SEFOS(config)# exit SEFOS# show vlan Vlan database ------------- Vlan ID : 1 Member Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Untagged Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Forbidden Ports : None Name : Status : Permanent ---------------------------------------------------- Vlan ID : 2 Member Ports : Ex0/3 Untagged Ports : None Forbidden Ports : None Name : Status : Permanent ------------------------------------------
SEFOS# show vlan Vlan database ------------- Vlan ID : 1 Member Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Untagged Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Forbidden Ports : None Name : Status : Permanent ---------------------------------------------------- Vlan ID : 2 Member Ports : Ex0/3, Ex0/4 Untagged Ports : None Forbidden Ports : None Name : Status : Dynamic Gvrp -------------------------------------------------
The switch propagates the VLAN declaration or registration on all the forwarding ports in the switch. In the preceding example, when VLAN 2 was created on the root bridge (switch 2), the switch propagated this information on all of the forwarding ports (Ex0/3 and Ex0/4), thus allowing switch 1 to learn about VLAN 2 through two ports (Ex0/3 and Ex0/4) using GVRP.
