| Skip Navigation Links | |
| Exit Print View | |
man pages section 9: DDI and DKI Kernel Functions Oracle Solaris 10 8/11 Information Library |
csx_AccessConfigurationRegister(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_intr_get_supported_types(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_string_array(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_string_array(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_range_uint32(9F)
net_event_notify_unregister(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_protocol_notify_register(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64_array(9F)
nvpair_value_boolean_array(9F)
scsi_get_device_type_scsi_options(9F)
scsi_sense_cmdspecific_uint64(9F)
usb_get_current_frame_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
- post error reports for the generic PCI errors logged in the PCI Configuration Status register.
#include <sys/sunddi.h> void pci_ereport_setup(dev_info_t *dip, int);
void pci_ereport_teardown(dev_info_t *dip);
void pci_ereport_post(dev_info_t *dip, ddi_fm_error_t *dep,
uin16_t *status);Solaris DDI specific (Solaris DDI)
Pointer to the dev_info structure of the devices
Pointer to DDI error status
Pointer to status bit storage location
The pci_ereport_setup() function initializes support for error report generation and sets up the resources for subsequent access to PCI, PCI/X or PCI Express Configuration space. The caller must have established a fault management capability level of at least DDI_FM_EREPORT_CAPABLE with a previous call to ddi_fm_init() for dip.
The pci_ereport_teardown() function releases any resources allocated and set up by pci_ereport_setup() and associated with dip.
The pci_ereport_post() function is called to scan for and post any PCI, PCI/X or PCI Express Bus errors. On a PCI bus, for example, the errors detected include:
Detected Parity Error
Master Data Parity Error
Target Abort
Master Abort
System Error
Discard Timeout
The pci_ereport_post() function must be called only from a driver's error handler callback function. See ddi_fm_handler_register(9F). The error_status argument to the error handler callback function should be passed through as the dep argument to pci_ereport_post() as it may contain bus specific information that might be useful for handling any errors that are discovered.
The fme_flag in the error_status argument to the error handler callback function will contain one of the following:
Any errors discovered are unexpected.
Errors discovered were the result of a DDI_ACC_CAUTIOUS operation.
Errors discovered are the result of a ddi_poke(9F) operation.
Errors discovered are the result of a ddi_peek(9F) operation.
Error report events are generated automatically if fme_flag is set to DDI_FM_ERR_UNEXPECTED and the corresponding error bits are set in the various PCI, PCI/X or PCI Express Bus error registers of the device associated with dip. The generated error report events are posted to the Solaris Fault Manager, fmd(1M), for diagnosis.
If the status argument is non-null, pci_ereport_post() saves the contents of the PCI Configuration Status Register to *status. If it is not possible to read the PCI Configuration Status Register, -1 is returned in *status instead.
On return from the call to pci_ereport_post(), the ddi_fm_error_t structure pointed at by dep will have been updated, and the fme_status field contains one of the following values:
No errors were detected which might affect this device instance.
An error which is considered fatal to the operational state of the system was detected.
An error which is not considered fatal to the operational state of the system was detected. The fme_acc_handle or fme_dma_handle fields in the returned ddi_fm_error_t structure will typically reference a handle that belongs to the device instance that has been affected.
An error was detected, but the call was unable to determine the impact of the error on the operational state of the system. This is treated the same way as DDI_FM_FATAL unless some other device is able to evaluate the fault to be DDI_FM_NONFATAL.
The pci_ereport_setup() and pci_ereport_teardown() functions must be called from user or kernel context.
The pci_ereport_post() function can be called in any context.
int xxx_fmcap = DDI_FM_EREPORT_CAPABLE | DDI_FM_ERRCB_CAPABLE;
xxx_attach(dev_info_t *dip, ddi_attach_cmd_t cmd) {
ddi_fm_init(dip, &xxx_fmcap, &xxx_ibc);
if (xxx_fmcap & DDI_FM_ERRCB_CAPABLE)
ddi_fm_handler_register(dip, xxx_err_cb);
if (xxx_fmcap & DDI_FM_EREPORT_CAPABLE)
pci_ereport_setup(dip);
xxx_err_cb(dev_info_t *dip, ddi_fm_error_t *errp) {
uint16_t status;
pci_ereport_post(dip, errp, &status);
return (errp->fme_status);
xxx_detach(dev_info_t *dip, ddi_attach_cmd_t cmd) {
pci_ereport_teardown(dip);
ddi_fm_handler_unregister(dip);
ddi_fm_fini(dip);
}See attributes(5) for descriptions of the following attributes:
fmd(1M), attributes(5), ddi_fm_handler_register(9F), ddi_fm_init(9F), ddi_peek(9F), ddi_poke(9F), ddi_fm_error(9S)
