The issues described in this topic are resolved in Oracle VM Server for SPARC 3.0.0.3. Upgrade your software to avoid these issues.
If you do not upgrade to system firmware 9.0.2 or newer, only single-DCU PDomain configurations support SDIO.
This is the known Direct I/O issue for the SPARC M6-32 and SPARC M5-32 servers:
