oracle home
SPARC M5-32 and SPARC M6-32 Servers Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC M5-32 and SPARC M6-32 Servers ...
Late-Breaking Information
Hardware Notes
Sun Flash Accelerator PCIe Card Support
Updated: March 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Hardware Notes
Troubleshooting DCU Boot Problems After Replacing Hardware
DCU Bootability With Mixed EMSs and HDD Card Cages
Identifying 1st Gen and 2nd Gen Components
EMS and HDD Cage Incompatibility
SPARC M5-32 Server Upgrades
Preinstalled Software
SPARC M6-32 Server Minimum Supported Versions of the Firmware, OS, and Software
SPARC M5-32 Server Minimum Supported Versions of the Firmware, OS, and Software
Oracle VM Server for SPARC Guidelines
Required OS Patches and Package Updates
Oracle Solaris 11 OS Package Updates
Oracle Solaris 10 OS Patches
Upgrade SPARC M6-32 Server System Firmware
Known Issues
Known General Issues
Memory Configurations
SP Status LEDs
EFI GPT Disk Label Support
Known Direct I/O Issues
System Sends Sigabrt Explicitly From Hypervisor Calls (16198869)
Known Oracle ILOM Issues
ILOM-8000-AF Description is Misleading (21265789)
PCIe Faults Reported Nonserviceable and Cannot Be Repaired (17317884)
Intermittent Recovery Failure From SLINK UEs (17290820)
Unable to Start Host After Firmware Upgrade and SPP Failover (17191941)
fmadm faulty Command Shows Duplicate Suspects (16996677)
Management of SP Does Not Display a Table as Expected (16607793)
Set the Number of Displayed Rows to a Maximum of 999
Display the System Log With Page Breaks
Need to Document How to Recover usbEthernet After PDomain-SPP Failover (16370459)
Oracle ILOM Reports EMS Hot-Plug Events in Reverse Order (15822281)
Known Oracle Solaris Issues
statvfs Fails on 32 TB Memory Configurations (17362334)
drand48 Routine Never Completes (17169064)
I/O Domains in Transition State After Reboot of Primary Domain (17020481)
Oracle Solaris px Driver Needs to Support PCI_IOV_SDIO_GROUP Version 2.1 (16739540)
Dual Path Disk LED Status Control Support (16458281)
CPU Power Management Can Drastically Lower Disk IOPS Performance (16355418)
Known Firmware Issue: SP Failover During Upgrading System Firmware From 9.2.1.c or Older to 9.3.0.c or Later (21051993)
Known Hardware Issue: EMS RJ45 Ethernet Speed and Activity LEDs Are Dim (16340264)
Known Documentation Issue: SPARC M5/M6-32 Service Manual Uses Inconsistent Hot-Plug-Swap Terminology (20238762)
Hot-Plug
Hot-Swap
Issues Resolved With Firmware Update
Language:
English
Hot-plugging of the Sun Flash Accelerator F40 and F80 PCIe cards is now supported.
Previous
Next
