| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Basic Library Functions Oracle Solaris 10 1/13 Information Library |
enable_extended_FILE_stdio(3C)
posix_spawnattr_getschedparam(3C)
posix_spawnattr_getschedpolicy(3C)
posix_spawnattr_getsigdefault(3C)
posix_spawnattr_getsigmask(3C)
posix_spawnattr_setschedparam(3C)
posix_spawnattr_setschedpolicy(3C)
posix_spawnattr_setsigdefault(3C)
posix_spawnattr_setsigmask(3C)
posix_spawn_file_actions_addclose(3C)
posix_spawn_file_actions_adddup2(3C)
posix_spawn_file_actions_addopen(3C)
posix_spawn_file_actions_destroy(3C)
posix_spawn_file_actions_init(3C)
pthread_attr_getdetachstate(3C)
pthread_attr_getinheritsched(3C)
pthread_attr_getschedparam(3C)
pthread_attr_getschedpolicy(3C)
pthread_attr_setdetachstate(3C)
pthread_attr_setinheritsched(3C)
pthread_attr_setschedparam(3C)
pthread_attr_setschedpolicy(3C)
pthread_barrierattr_destroy(3C)
pthread_barrierattr_getpshared(3C)
pthread_barrierattr_setpshared(3C)
pthread_condattr_getpshared(3C)
pthread_condattr_setpshared(3C)
pthread_cond_reltimedwait_np(3C)
pthread_mutexattr_getprioceiling(3C)
pthread_mutexattr_getprotocol(3C)
pthread_mutexattr_getpshared(3C)
pthread_mutexattr_getrobust_np(3C)
pthread_mutexattr_setprioceiling(3C)
pthread_mutexattr_setprotocol(3C)
pthread_mutexattr_setpshared(3C)
pthread_mutexattr_setrobust_np(3C)
pthread_mutex_consistent_np(3C)
pthread_mutex_getprioceiling(3C)
pthread_mutex_reltimedlock_np(3C)
pthread_mutex_setprioceiling(3C)
pthread_rwlockattr_destroy(3C)
pthread_rwlockattr_getpshared(3C)
pthread_rwlockattr_setpshared(3C)
pthread_rwlock_reltimedrdlock_np(3C)
pthread_rwlock_reltimedwrlock_np(3C)
pthread_rwlock_timedrdlock(3C)
pthread_rwlock_timedwrlock(3C)
rctlblk_get_enforced_value(3C)
- issue a shell command
#include <stdlib.h> int system(const char *string);
The system() function causes string to be given to the shell as input, as if string had been typed as a command at a terminal. The invoker waits until the shell has completed, then returns the exit status of the shell in the format specified by waitpid(3C).
If string is a null pointer, system() checks if the shell exists and is executable. If the shell is available, system() returns a non-zero value; otherwise, it returns 0. The standard to which the caller conforms determines which shell is used. See standards(5).
The system() function executes vfork(2) to create a child process that in turn invokes one of the exec family of functions (see exec(2)) on the shell to execute string. If vfork() or the exec function fails, system() returns -1 and sets errno to indicate the error.
The system() function fails if:
The system-imposed limit on the total number of processes under execution by a single user would be exceeded.
The system() function was interrupted by a signal.
The new process requires more memory than is available.
The system() function manipulates the signal handlers for SIGINT, SIGQUIT, and SIGCHLD. It is therefore not safe to call system() in a multithreaded process, since some other thread that manipulates these signal handlers and a thread that concurrently calls system() can interfere with each other in a destructive manner. If, however, no such other thread is active, system() can safely be called concurrently from multiple threads. See popen(3C) for an alternative to system() that is thread-safe.
ksh(1), sh(1), exec(2), vfork(2), popen(3C), waitpid(3C), attributes(5), standards(5)
