The topics in this section pertain to the options available for specific windows or dialog boxes in Developer Studio.
About automatic phrasing
When an application user provides individual search terms in a query, the automatic phrasing feature groups those individual terms into a search phrase and returns query results for the phrase.
Endeca IAP Workbench Settings dialog box
Specify the Endeca Workbench host, the port Endeca Workbench listens to, and associate instance configuration files with the application you select.
Enqueue URL dialog box
This shows the property storing URLs to other documents. You may remove Enqueue URL property from record after value is queued.
Importing phrases from an XML file
You import an XML file of phrases using the Import Phrases dialog box in Developer Studio. The Import Phrases dialog box can be accessed from either the File menu or from the Automatic Phrasing dialog box.
Join Entry dialog box
This shows the record source for this join entry, and options for adding, modifying, or removing key components of this entry's join key.
Mappings dialog box
This dialog contains a Mappings table, and options to create new, modify, or remove mappings.
Member Options dialog box (snippeting)
You enable the snippeting feature in the Member Options dialog box. Each member of a search interface is enabled and configured separately.
New Project dialog box
You may create a project from a template. This dialog is also where you name and save your project.
