For specific PCIe card removal instructions, refer to the system service manual and product notes.
Refer to the servers service manual.
Power down the system.
![]() | Caution - Electric shock hazard. Disconnect the server from the main power and from any networks before installing the card to avoid electrical shock. |
Remove the bracket screw.
Carefully lift the card out of the PCIe slot to remove the card.
![]() | Caution - Hot surface. Avoid contact. Equipment surfaces are hot and might cause personal injury if touched. |
Figure 4 Sun Flash Accelerator F80 PCIe Card Removal
Figure Legend
1Bracket screw
2Lift here
Refer to Install a New Card.
