Use the following table to record your Exadata Storage Server disk group layout for each cluster. Note that the worksheet has entries for eight clusters, but you could have more than eight clusters in your Oracle SuperCluster M7, depending on the number of Database Domains that have zones that are members of each cluster, the size of the zones in each cluster, and so on. Copy the worksheet if you have more than eight clusters in your system.
Assign a name to each disk group that designates it as a specific type of disk group for a specific cluster, as described in Planning the Exadata Storage Server Disk Group Layout. For example, if the name of a particular cluster is scm7r1, then the names of the disk groups for that cluster should be something similar to the following:
DATA_scm7r1
RECO_scm7r1
DBFS_scm7r1
