Remove the Cable Management Arm
Follow this procedure to remove the cable management arm (CMA).
Before you begin this procedure, refer to the illustration in Step 1 and identify CMA connectors A, B, C, and D. You should
disconnect the CMA connectors in the reverse order in which you installed them, that is,
disconnect connector D first, then C, then B, and finally A.
Throughout this procedure, once you disconnect any of the CMA's four connectors, do
not allow the CMA to hang under its own weight.
Note -
References to “left” or “right” in this procedure
assume that you are facing the back of the equipment rack.
To prevent the rack from tipping forward when the storage server is extended, extend all rack
anti-tilt devices.
 | Caution -
To reduce the risk of personal injury, stabilize the rack cabinet and extend
all anti-tilt devices before extending the storage server from the rack. For
instructions for stabilizing the rack, see Stabilize the Rack for Installation.
Disconnect all cables from the rear of the storage server.
- Extend the storage server approximately 13 cm (5 inches) out of the front of the rack.
- To remove the cables from the
CMA:
- If applicable, remove any additional
Velcro straps that were installed to bundle the cables.
- Unwrap the six Velcro straps
that are securing the cables.
- Open the three cable covers to
the fully opened position.
- Remove the cables from the CMA
and set them aside.
- To disconnect connector D:
- Press the green release
tab (callout 1) on the slide-rail latching bracket toward the left
and slide the connector D out of the left slide-rail [frames 1 and
2].
When you slide connector D out of the left slide-rail, the slide-rail
latching bracket portion of the connector remains in place. You will disconnect
it in the next step.
Note -
Once you have disconnected connector D, do not allow the CMA to
hang under its own weight. Throughout the remainder of this
procedure, the CMA must be supported until all the remaining
connectors are disconnected and the CMA can be placed on a flat
surface.
1
Connector D release tab (green)
2
Slide-rail latching bracket release tab (labeled PUSH)
- Use your right hand to support the CMA.
Use your left thumb to push in (toward the left) on the connector D latching
bracket release tab labeled PUSH (callout 2), and pull the latching bracket out
of the left slide-rail and put it aside [frames 3 and 4].
- To disconnect connector C:
- Place your left arm
under the CMA to support it.
- Use your right thumb to push
in (toward the right) on the connector C release tab labeled PUSH
(callout 1), and pull connector C out of the right slide-rail [frames
1 and 2].
1
Connector C release tab (labeled PUSH)
- To disconnect connector B:
- Place your right arm
under the CMA to support it and grasp the rear end of connector
B with your right hand.
- Use your left thumb to pull the
connector B release lever to the left away from the right slide-rail
(callout 1) and use your right hand to pull the connector out of
the slide-rail [frames 1 and 2].
1
Connector B release lever
- To disconnect connector A:
A with your left hand.
- Use your right thumb to pull
the connector A release lever to the right away from the left slide-rail
(callout 1), and use your left hand to pull the connector out of
1
Connector A release lever
- Remove the CMA from the rack
and place it on a flat surface.
- Go to the front of the storage server
and push it back into the rack.
