Attach Tool-Less Slide-Rail Assemblies
Use this procedure to attach tool-less slide-rail assemblies to the rack.
- Orient
the slide-rail assembly so that the ball-bearing track is forward
and locked in place.
1
Slide-rail
2
Ball-bearing track
3
Locking mechanism
- Starting with either the left or right
side of the rack, align the rear of the slide-rail assembly against
the inside of the rear rack rail, and push until the assembly locks
into place with an audible click.
- Align the front of the slide-rail assembly
against the outside of the front rack rail, and push until the assembly
locks into place with an audible click.
- Repeat Step 1 through Step 3 to
attach the slide-rail assembly to the other side of the rack.
