시작하기 전에
ASR Manager를 등록할 때, 필요한 경우 정보 및 프록시 서버에 MOS Single Sign-On을 입력합니다.
# asr register
1) transport.oracle.com
다음과 같이 화면이 출력됩니다.
Proxy server name: ? <proxy server name> Proxy port number: ? <proxy port number> Proxy authentication; if authentication is not required, enter -. Proxy user: <proxy user name> Proxy password: <proxy password> If this is an NTLM type proxy, enter the information below. Otherwise, enter - NTLM Domain: [?] <NTLM domain name> Enter the host the NTLM authentication request is originating from. Usually this is the hostname of the SASM server. NTLM Host: [?] <NTLM host name> NTLM support is not bundled with SASM but may be added now. 1) Download jCIFS from http://jcifs.samba.org/ 2) Extract contents and locate the jcifs-*.jar file 3) Enter full path to this file below jCIFS jar file: [?] <full path of jCIFS jar file> Note: These properties are stored in the /var/opt/SUNWsasm/configuration/config.ini file. You can update these properties if needed and then restart SASM.
MOS 전자 메일 주소는 ASR 문제 및 서비스 요청(Service Request, SR) 생성 알림으로부터 출력 결과를 수신합니다.
