3.1.2 Maintenance Window Tasks
Table 3-3 Timeline table for Full upgrade of ELAP
LSMS
Procedure Task Time Task Start time (min)
SM Migration, Appendix D
Disconnect NPAC from LSMS
5
0
Procedure 4
*LSMS Servdi Backup
170
175
*LSMS Servdi backup time will vary according to the data on LSMS. This has to be done simultaneously while IPMing the ELAP servers.
Table 3-4 Timeline table for Full upgrade of ELAP
ELAP A   ELAP B
Procedure Task A Task Start time (min) B Task Procedure
Procedure 5
Backup EuiDB with
MyISAM engine and InnoDB engine
15
15
Procedure 6
Disconnect ELAP from
LSMS
5
20
25
45
IPM MPS server with TPD 8.10.x
Procedure 7
70
10
Pre-install configuration
Procedure 8
80
30
ELAP installation steps
Procedure 9
110
10
Configure Network for Backup transfer
Procedure 10
Procedure 15
Transfer backup to local B
5
115
Procedure 7
8..x
45
120
Procedure 8
10
165
Procedure 9
30
175
For Telco Switch-Procedure 11
For Cisco Switch- Procedure A.2
Switch Configuration
30
205
Procedure 12
*Configure NTP server
5
210
Procedure 13
Initial Network Configuration
10
220
Procedure 14
Verify Configurations
5
225
230
5
A
Procedure 15
Procedure 16
Restore EuiDB
5
235
Procedure 17
SSH key exchange between ELAP and LSMS
5
240
Procedure 18
Repoint LSMS to ELAP VIP
15
255
Procedure 19
Transfer Servdi Image To
ELAP
5
260
Procedure 20
Restore Servdi
15
275
SM Migration, Appendix E
Connect NPAC to LSMS
5
280
Procedure 21
Post Upgrade Syscheck
5
280
5
Procedure 21
Procedure 22
Accept The Upgrade
5
285
5
Accept The Upgrade
Procedure 22
* After ELAP installation, switch configuration is done before configuring NTP server and initial configuration, it will take an extra 30 minutes to configure the switches. Follow Procedure A.1 and Procedure A.2 for Cisco switch configuration steps and Procedure 11 for Telco switch configuration.
After accepting upgrade on ELAP, the SCCP cards at EAGLE should be initialized to load the ELAP DB. Follow Procedure 25.
