Defining a Characteristic for the Product
Prerequisites
To define a characteristic to the product, you should have:
Product defined in the application.
Characteristic type defined in the application.
Procedure
To define a characteristic type to the product:
Ensure that the Additional Attributes section is expanded in the Other Details zone
of Basic Details page when you are defining
the characteristic type to the product.
The Additional Attributes zone contains the following fields:
Field Name Field Description Mandatory (Yes or No) Effective Date Used to specify the date from when a characteristics type and characteristics value is effective. Yes Characteristics Type Used to indicate the characteristic type. Yes Characteristics Value Used to specify the value for the characteristic type. Yes - Enter the required details in the Additional Attributes section.
- Click Save as Draft, to save the product in the draft.
Click Next, to go to Other Detailspage.
The product is saved as draft in the application.
Related Topics
For more information on... | See... |
Other Details Page | Product Information - Other Details |
Other Details Zone | Other Details |
