On a SPARC SuperCluster T4-4 that offers Capacity-on-Demand , a number of the cores on the compute servers can be enabled or disabled logically using the ssccod utility. Using the utility, a system can increase compute server CPU processing power when needed and then decrease it when the power is not needed. For example, a business may run 24 of the 32 cores (75%) in each SPARC SuperCluster T4-4 compute server the majority of time, and then enable the other 8 cores during the end of the quarter for running reports and queries. After the quarter-end processing is done, the 8 cores can be disabled. It is not necessary to restart the servers after running the script.
Capacity-on-Demand can be managed with the following script:
ssccod { -capacity_on_demand | -cod } { display | enable | disable }
This utility needs to be run in the control domain of each SPARC SuperCluster T4-4 compute node. To establish which nodes are your control domains, use the virtinfo shell command, which will specify "LDoms control" if you are in the control domain, e.g.:
$ /usr/sbin/virtinfo Domain role: LDoms control I/O service root
The following table describes the parameters used with the ssccod utility.
