Enable SDP Support for JDBC
Complete the following steps:
Ensure that you have created the Grid Link Data Sources for the JDBC
connectivity on ComputeNode1 and
ComputeNode2, as described in Section 7.6
“Configuring Grid Link Data Source for Dept1_Cluster1” of the
Oracle® Fusion Middleware Exalogic
Enterprise Deployment Guide at http://docs.oracle.com/cd/E18476_01/doc.220/e18479/optimization.htm#BABHEDI.
The console automatically generates the complete JDBC URL, as shown in the
following example:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=192.x.x.x)(PORT=1522))(CONNECT_DATA=(SERVICE_NAME=myservice)))
In the JDBC URL, replace TCP protocol with
SDP protocol. For example:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=sdp)(HOST=192.x.x.x)(PORT=1522))(CONNECT_DATA=(SERVICE_NAME=myservice)))
Manually add the system property
-Djava.net.preferIPv4Stack=true to the
startWebLogic.sh script, which is located in
the bin directory of
base_domain, using a text editor as
follows:
Locate the following line in the
startWebLogic.sh script:
. ${DOMAIN_HOME}/bin/setDomainEnv.sh
Add the following property immediately after the above
entry:
JAVA_OPTIONS="${JAVA_OPTIONS}
-Doracle.net.SDP=true"
Save the file and close.
Restart the Managed Server as follows:
In the administration console, click
Environment >
Servers. The Summary of Servers page
is displayed.
Select a Managed Server, such as WLS1,
by clicking WLS1. The Settings for WLS1
page is displayed.
Click the Control tab. Select
WLS1 in the Server Status table.
Click Start.
