oracle home
SPARC SuperCluster T4-4 Owner's Guide
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC SuperCluster T4-4 Documentation Library
Maintaining the System
Powering Off the System
Updated: February 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding the System
SPARC SuperCluster T4-4 Overview
Spares Kit Components
SPARC SuperCluster T4-4 Restrictions
Identifying Hardware Components
Full Rack Components
Half Rack Components
Understanding the Hardware Components and Connections
SPARC T4-4 Servers
Exadata Storage Servers
Sun ZFS Storage 7320 Appliance
Sun Datacenter InfiniBand Switch 36 Switches
Cisco Catalyst 4948 Ethernet Management Switch
Power Distribution Units
Understanding the Physical Connections
SPARC T4-4 Server Physical Connections
Card and Port Locations (SPARC T4-4 Servers)
InfiniBand Private Network Physical Connections (SPARC T4-4 Servers)
Oracle ILOM Management Network Physical Connections (SPARC T4-4 Servers)
1 GbE Host Management Network Physical Connections (SPARC T4-4 Servers)
10 GbE Client Access Network Physical Connections (SPARC T4-4 Servers)
Exadata Storage Server Physical Connections
InfiniBand Private Network Physical Connections (Exadata Storage Servers)
Oracle ILOM Management Network Physical Connections (Exadata Storage Servers)
1 GbE Host Management Network Physical Connections (Exadata Storage Servers)
Sun ZFS Storage 7320 Appliance Physical Connections
InfiniBand Private Network Physical Connections (Sun ZFS Storage 7320 Appliance)
Oracle ILOM Management Network Physical Connections (Sun ZFS Storage 7320 Appliance)
1 GbE Host Management Network Physical Connections (Sun ZFS Storage 7320 Appliance)
SAS Physical Connections (Sun ZFS Storage 7320 Appliance)
Cluster Physical Connections (Sun ZFS Storage 7320 Appliance)
Power Distribution Units Physical Connections
Understanding the SPARC SuperCluster T4-4 Configurations
Understanding Logical Domains and the Express Module Slots
Understanding the Management Network
Understanding the 10 GbE Client Access Network
Understanding the InfiniBand Network
InfiniBand Network Data Paths for a Database Domain
InfiniBand Network Data Paths for an Application Domain
Understanding Clustering Software
Cluster Software for the Database Domain
Cluster Software for the Oracle Solaris Application Domains
Example SPARC SuperCluster T4-4 Configuration
Database Domain
CPU, Memory, and PCI Root Complex Resource Allocation
InfiniBand Connections
At the SPARC T4-4 Server Level
At the SPARC SuperCluster T4-4 Level
10 GbE Client Access Connections
Application Domain Running Oracle Solaris 10
Understanding the Network Requirements
Network Requirements Overview
Network Connection Requirements for SPARC SuperCluster T4-4
Default IP Addresses (SPARC SuperCluster T4-4)
Default Host Names and IP Addresses (Full Rack)
Default Host Names and IP Addresses for the Oracle ILOM and Host Management Networks (Full Rack)
Default Host Names and IP Addresses for the InfiniBand and 10 GbE Client Access Networks (Full Rack)
Default Host Names and IP Addresses (Half Rack)
Default Host Names and IP Addresses for the Oracle ILOM and Host Management Networks (Half Rack)
Default Host Names and IP Addresses for the InfiniBand and 10 GbE Client Access Networks (Half Rack)
Preparing the Site
Cautions and Considerations
Reviewing System Specifications
Physical Specifications
Installation and Service Area
Rack and Floor Cutout Dimensions
Reviewing Power Requirements
System Power Consumption
Facility Power Requirements
Grounding Requirements
PDU Power Requirements
Preparing for Cooling
Environmental Requirements
Heat Dissipation and Airflow Requirements
Perforated Floor Tiles
Preparing the Unloading Route and Unpacking Area
Shipping Package Dimensions
Loading Dock and Receiving Area Requirements
Access Route Guidelines
Unpacking Area
Preparing the Network
Network IP Address Requirements
Prepare DNS for the System
Installing the System
Installation Overview
Oracle Safety Information
Unpacking the System
Tools for Installation
Find the Unpacking Instructions
Unpack and Inspect the Machine
Moving the Rack Into Place
Move the SPARC SuperCluster T4-4
Install a Ground Cable (Optional)
Adjust the Leveling Feet
Powering on the System the First Time
Connect Power Cords to the Rack
Power On the SPARC SuperCluster T4-4
Connect a Laptop to the SPARC SuperCluster T4-4
Connect to a 10 GbE Client Access Network
Using an Optional Fiber Channel Express Module
Cautions and Warnings
Graceful Power Off Sequence
Shut Down the Exadata Storage Servers
Power Off the Exadata Storage Servers
Gracefully Shut Down LDoms
Emergency Power Off
Power On the System
Managing Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Remove Unwanted Boot Environments
Using Dynamic Intimate Shared Memory
DISM Restrictions
Disable DISM
Component-Specific Service Procedures
Maintaining Exadata Storage Servers
Monitor Write-through Caching Mode
Shut Down an Exadata Storage Server
Drop an Exadata Storage Server
Tuning SPARC SuperCluster
Monitor ssctuner
Turn Off ssctuner
Disable Individual ssctuner Components
Configuring CPU and Memory Allocation
CPU/Memory Tool Overview
Supported CPU/Memory Allocations
Change CPU/Memory Allocations
Revert to a Previous CPU/Memory Configuration
Enabling and Disabling Capacity-on-Demand on SPARC SuperCluster
Monitoring the System
Monitoring the System Using Auto Service Request
ASR Overview
Preparing to Configure ASR
Prepare the ASR Environment
Software Requirements: ASR Manager
Software Requirements: SPARC SuperCluster T4-4
Installing ASR Manager Components
Install the Oracle Automated Service Manager (OASM) Package
Install Service Tools Bundle (STB) for Solaris Only
Install the Oracle Auto Service Request (ASR) Package
Register ASR Manager
Verify ASR Manager
Configure SNMP Trap Destinations for the Exadata Storage Servers
Configure ASR on the Sun ZFS Storage 7320 Storage Appliance
Configure ASR on the SPARC T4-4 Servers: Oracle ILOM
Configuring ASR on the SPARC T4-4 Servers: Oracle Solaris 11
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on the ASR Manager (Optional)
Register the SPARC T4-4 Server with Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Activation for SPARC SuperCluster T4-4 Assets
Monitoring the System Using OCM
OCM Overview
Install Oracle Configuration Manager on the SPARC T4-4 Servers
Monitoring the System Using EM Exadata Plug-in
Configuring Exalogic Software
Overview of Exalogic-Specific Enhancements
Exalogic Software Prerequisites
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Fast Connection Failover
Runtime Connection Load Balancing
XA Affinity
SCAN Addresses
Secure Communication using Oracle Wallet
Create a GridLink Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support Infiniband
Enable SDP Support for JDBC
Monitor SDP Sockets Using netstat on Oracle Solaris
Configuring SDP InfiniBand Listener for Exalogic Connections
Create an SDP Listener on the InfiniBand Network
Understanding Internal Cabling
Reference Drawings
InfiniBand Fabric
IB Spine Switch
IB Leaf Switch No. 1
IB Leaf Switch No. 2
Ethernet Management Switch Connections in a Full Rack
Ethernet Management Switch Connections in a Half Rack
Single-Phase PDUs
Three-Phase PDUs
Connecting Multiple SPARC SuperCluster T4-4 Systems
Multi-Rack Cabling Overview
Two-Rack Cabling
Three-Rack Cabling
Four-Rack Cabling
Five-Rack Cabling
Six-Rack Cabling
Seven-Rack Cabling
Eight-Rack Cabling
Connecting Expansion Racks
Oracle Exadata Storage Expansion Rack Components
Preparing for Installation
Network Connection and IP Address Requirements
Installing the Oracle Exadata Storage Expansion Rack
Cabling Tables (Internal)
Front and Rear Views of the Oracle Exadata Storage Expansion Rack
Oracle ILOM Cabling Tables
Administrative Gigabit Ethernet Port Cabling Tables
Single Phase Power Distribution Unit Cabling Tables
Three Phase Power Distribution Unit Cabling Tables
InfiniBand Network Cabling Tables
Connecting an Oracle Exadata Storage Expansion Rack to the SPARC SuperCluster T4-4
InfiniBand Switch Information for the SPARC SuperCluster T4-4
InfiniBand Switch Information for the Oracle Exadata Storage Expansion Rack
Connecting an Oracle Exadata Storage Expansion Quarter Rack to the SPARC SuperCluster T4-4
Connecting an Oracle Exadata Storage Expansion Half Rack or Oracle Exadata Storage Expansion Full Rack to the SPARC SuperCluster T4-4
Two-Rack C20abling
Three-Rack Cabling
Four-Rack Cabling
Five-Rack Cabling
Six-Rack Cabling
Seven-Rack Cabling
Eight-Rack Cabling
Index
Index A
Index B
Index C
Index D
Index E
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Language:
English
Emergency Power Off
Previous
Next
