Complete the following steps on each Exadata Storage Server:
# cellcli -e “alter cell snmpSubscriber=(host ='ASR-Manager-name-or-IP-address',port=162,community=public,type=asr)”
Note that single quotes are required around the ASR-Manager-name-or-IP-address entry. Following are the element definitions for the command above:
host='ASR-Manager-name-or-IP-address' – The ASR Manager hostname can be used when DNS is enable for the site. If DNS is not running, the IP address is preferred, but the ASR Manager hostname can be used if the entry is added to the /etc/hosts file.
type=asr – Shows the ASR Manager as being a special type of SNMP subscriber.
community=public – The required value of the community string. This value can be modified to be a different string based on customer network requirements.
port=162 – The SNMP port. This port value is customer dependant. It can be configured as a different port based on network requirements, or it may need to be changed for ASR to work correctly in a managed environment.
# asr list_asset
Following is example output:
IP_ADDRESS HOST_NAME SERIAL_NUMBER ASR PROTOCOL SOURCE ---------- --------- ------------- --- -------- ----- 10.60.40.105 ssc1cel01 1234FMM0CA Enabled SNMP ILOM 10.60.40.106 ssc1cel02 1235FMM0CA Enabled SNMP ILOM 10.60.40.107 ssc1cel03 1236FMM0CA Enabled SNMP ILOM 10.60.40.117 ssc1cel01-ilom 1234FMM0CA Enabled SNMP,HTTP EXADATA-SW 10.60.40.118 ssc1cel02-ilom 1235FMM0CA Enabled SNMP,HTTP EXADATA-SW 10.60.40.119 ssc1cel03-ilom 1236FMM0CA Enabled SNMP,HTTP EXADATA-SW
# asr activate_asset -i ILOM-IP-address
or
# asr activate_asset -h ILOM-hostname
# asr activate_exadata -i host-management-IP-address -h host-management-hostname -l ILOM-IP-address
or
# asr activate_exadata -i host-management-IP-address -h host-management-hostname -n ILOM-hostname
# asr list_asset
You should see both the Oracle ILOM and the host referenced in the list, with the same serial number, as shown in the following example output:
# cellcli -e “list cell attributes snmpsubscriber”
# cellcli -e “alter cell validate snmp type=asr”
The MOS contact will receive an email as confirmation.
See Approve and Verify ASR Activation for SPARC SuperCluster T4-4 Assets for those instructions.
For more information on the process, see ASR MOS 5.3+ Activation Process (Doc ID 1329200.1).
