Confirming Server and Site Specifications
Install Mounting Brackets on Server
Attach Slide Rail Assemblies to Rack
Connecting Data and Management Cables
Secure Cables to CMA (Optional)
Powering On the Server for the First Time
Connect a Terminal or Emulator to the SER MGT Port
Power On the System for the First Time
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Understanding System Administration Resources
Platform-Specific Oracle ILOM Features
Oracle VM Server for SPARC Overview
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Display the Oracle ILOM -> Prompt
Power On the Server (Oracle ILOM)
Power Off the Server (Oracle ILOM)
Reset the Server (Oracle Solaris OS)
Reset the Server (Oracle ILOM)
Reset the SP to Default Values
Important Hardware RAID Guidelines
Prepare to Use the FCode Utility
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
RAID Drive Replacement Strategies
Changing Server Identification Information
Change Customer Data on FRU PROMs
Change System Identifier Information
Restore the Host Power State at Restart
Specify the Host Power State at Restart
Disable or Re-Enable the Host Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior (Keyswitch State)
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the IP Address of the SP
Using an In-band Connection to the SP
Configure the Host Boot Mode (Oracle VM Server for SPARC)
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Enabling Automatic System Recovery
Identifying WWN-Designated SAS2 Devices
Mapping WWN Values to Hard Drives (OBP probe-scsi-all Command)
probe-scsi-all WWN Mapping Overview
probe-scsi-all WWN Mapping Example (SPARC T4-1)
probe-scsi-all WWN Mapping Example (Netra SPARC T4-1)
probe-scsi-all WWN Mapping Example (SPARC T4-2)
probe-scsi-all WWN Mapping Example (Netra SPARC T4-2)
probe-scsi-all WWN Mapping Example (SPARC T4-4 With Four CPUs)
probe-scsi-all WWN Mapping Example (SPARC T4-4 With Two CPUs)
probe-scsi-all WWN Mapping Example (SPARC T4-1B and Netra SPARC T4-1B)
WWN Syntax in an OS Installation on an Individual Drive
WWN Syntax in an OS Installation on a RAID Volume
Infrastructure Boards in the Server
Interpreting Log Files and System Messages
Checking if Oracle VTS Is Installed
Understanding Component Replacement Categories
Removing Power From the Server
Positioning the System for Servicing
Attaching Devices to the Server
Verify Fan Module Functionality
Verify Power Supply Functionality
Servicing Memory Risers and DIMMs
Locate a Faulty DIMM (DIMM Fault Remind Button)
Locate a Faulty DIMM (show faulty Command)
Increase Server Memory With Additional DIMMs
Increase Server Memory with Additional DIMMs (16 Gbyte Configurations)
Remove a Memory Riser Filler Panel
Install a Memory Riser Filler Panel
DIMM Configuration Error Messages
Remove a DVD Drive or Filler Panel
Install a DVD Drive or Filler Panel
Servicing the System Lithium Battery
Servicing Expansion (PCIe) Cards
Remove a PCIe Card Filler Panel
Cable an Internal SAS HBA PCIe Card
Install a PCIe Card Filler Panel
Verify Fan Board Functionality
Verify Motherboard Functionality
Verify Drive Backplane Functionality
Servicing the Power Supply Backplane
Remove the Power Supply Backplane
Install the Power Supply Backplane
Verify Power Supply Backplane Functionality
Return the Server to the Normal Rack Position
The procedure described below applies to SPARC T4-1 and SPARC T4-4 servers, which have eight-disk backplane configurations. The same methodology can be used for the SPARC T4-2 server and SPARC T4-1B blade systems.
# format Searching for disks...done AVAILABLE DISK SELECTIONS: 0. c0t5000CCA00ABBAEB8d0 <SUN300G cyl 46873 alt 2 hd 20 sec 625> /scsi_vhci/disk@g5000cca00abbaeb8 1. c0t5000C5001D40D7F7d0 <SUN300G cyl 46873 alt 2 hd 20 sec 625> /scsi_vhci/disk@g5000c5001d40d7f7 [...]
The remaining steps in this example will identify the physical slot that corresponds to the device name c0t5000CCA00ABBAEB8d0.
Device Minor Nodes: dev=(32,0) dev_path=/scsi_vhci/disk@g5000cca00abbaeb8:a spectype=blk type=minor dev_link=/dev/dsk/c0t5000CCA00ABBAEB8d0s0 <<=== Device link dev_link=/dev/sd3a dev_path=/scsi_vhci/disk@g5000cca00abbaeb8:a,raw spectype=chr type=minor dev_link=/dev/rdsk/c0t5000CCA00ABBAEB8d0s0 <<=== Device link dev_link=/dev/rsd3a
Note the obp-path value listed under WWN 5000cca00abbaeb8.
Refer to the following table to find the controller.
For SPARC T4-1 servers, the controller is identified in the second field: pci@1 = controller 0 and pci@2 = controller 1.
For SPARC T4-4 servers, the controller is identified in the first field. For systems with a four-processor configuration, pci@400 = controller 0 and pci@700 = controller 1. For systems with a two-processor configuration, pci@400 = controller 0 and pci@500 = controller 1.
Note - Because SPARC T4-2 and SPARC T4-1B systems contain only one SAS controller, only controller 0 will be listed.
The following output example shows the obp-path for a SPARC T4-1 server.
Paths from multipath bus adapters: mpt_sas#5 (online) name='wwn' type=string items=1 value='5000cca00abbaeb8' <<=== Hard drive WWN ID name='lun' type=int items=1 value=00000000 name='target-port' type=string items=1 value='5000cca00abbaeb9' <<=== Hard drive SAS address name='obp-path' type=string items=1 value='/pci@400/pci@1/pci@0/pci@4/scsi@0/disk@w5000cca00abbaeb9,0' name='phy-num' type=int items=1 value=00000000 name='path-class' type=string items=1 value='primary'
In this SPARC T4-1 example, the obp-path is:
Based on the previous table, this disk is on controller 0.
The following output example shows the obp-path for a SPARC T4-4 server.
Paths from multipath bus adapters: mpt_sas#5 (online) name='wwn' type=string items=1 value='5000cca00abbaeb8' <<=== Hard drive WWN ID name='lun' type=int items=1 value=00000000 name='target-port' type=string items=1 value='5000cca00abbaeb9' <<=== Hard drive SAS address name='obp-path' type=string items=1 value='/pci@400/pci@1/pci@0/LSI,sas@0/disk@w5000cca00abbaeb9,0' name='phy-num' type=int items=1 value=00000000 name='path-class' type=string items=1 value='primary'
In this SPARC T4-4 example, the obp-path is:
/pci@400/pci@1/pci@0/pci@0/LSI,sas@0/disk@w5000cca00abbaeb9,0
