man pages section 9: DDI and DKI Properties and Data Structures
Exit Print View
Updated: July 2014
mac_group_info(9S)
Name
mac_group_info - group Information data structure
Synopsis
#include <sys/mac_provider.h>
Interface Level
Solaris architecture specific (Solaris DDI)
Description
The mac_group_info structure is used by a network device driver to describe its ring groups and the groups capabilities. The structure is used as the argument to the mr_gget (9E) driver entry point when querying the group and its capabilities.
Structure Members
mac_group_driver_t              mgi_driver;
mac_group_start_t               mgi_start;
mac_group_stop_t                mgi_stop;
uint_t                          mgi_count;
mac_group_flags_t               mgi_flags;
mac_group_addmac_t              mgi_addmac;
mac_group_remmac_t              mgi_remmac;
mac_group_addvlan_t             mgi_addvlan;
mac_group_remvlan_t             mgi_remvlan;
mac_group_setmtu_t              mgi_setmtu;
mac_group_getsriov_info_t       mgi_getsriov_info;
mgi_driver
Filled by the driver as handle to the driver's group structure.
mgi_start
The driver entry point for starting a driver's ring group.
mgi_stop
The driver entry point for stopping a driver ring group.
mgi_count
The number of rings that are members of this ring group.
mgi_flags
Set by the driver to indicate various ring group capabilities including whether the group is the default ring group for the interface, whether the group is a pool of non-active rings, whether the group implements tagging/stripping for all VLANs, or implements transparent VLANs.
mgi_addmac
The driver entry point to program a MAC address into the driver's hardware for this ring group. This entry is only for RX ring groups. For SRIOV-capable devices, the MAC_GROUP_MACADDR_PRIMARY flag will be used to identify which of the MAC addressed for the group is the primary MAC address of the VF.
mgi_remmac
The driver entry point to remove a previously programmed MAC address.
mgi_addvlan
The driver entry point to add a VLAN filter to the ring group. The MAC_VLAN_FILTER_TAG_ENABLE flag will be set if the group is to provide tagging/stripping offload.
mgi_remvlan
The driver entry point to remove a VLAN filter.
mgi_setmtu
The driver entry point for the MAC layer to set the MTU for the ring group.
mgi_getsriov_info
The driver entry point to get the SRIOV information associated with this group.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/header
Interface Stability
Committed
See also
attributes(5), mac_capab_rings(9E) , mac_group_info(9E), mr_gget (9E), mac_register(9S)
