man pages section 9: DDI and DKI Properties and Data Structures
Exit Print View
Updated: July 2014
mac_ring_info(9S)
Name
mac_ring_info - ring information data structure
Synopsis
#include <sys/mac_provider.h>
Interface Level
Solaris architecture specific (Solaris DDI)
Description
The mac_ring_info structure is used by a network device driver to describe it's RX and TX rings. The structure is used as an argument to the mr_rget driver entry point when querying the ring.
Structure Members
mac_ring_driver_t       mri_driver;
mac_ring_start_t        mri_start;
mac_ring_stop_t         mri_stop;
mac_intr_enable_t       mri_intr_enable;
mac_intr_disable_t      mri_intr_disable;
ddi_intr_handle_t       mri_intr_ddi_handle;
mac_ring_send_t         mri_tx;
mac_ring_poll_t         mri_poll;
mac_ring_stat_t         mri_stat;
uint_t                  mri_flags;
mri_driver
Filled by the driver as handle to the driver's ring structure.
mri_start
The driver entry point for starting a driver's ring.
mri_stop
The driver entry point for stopping a driver ring.
mri_stat
The driver entry point for getting statistics for ring.
mrii_tx
The driver entry point for transmitting packet for TX rings.
mri_poll
The driver entry point for polling RX ring for packets.
mri_flags
A set of flags for describing ring behavior.
mri_intr_ddi_handle
The DDI interrupt handle associated with the interrupt for this ring.
mri_intr_enable
For RX rings, this driver entry point will enable interrupts again and transition the driver polling to interrupt mode.
mri_intr_disable
For RX rings, this driver entry point will disable interrupts and place the driver into polling mode.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/header
Interface Stability
Committed
See also
attributes(5), mac_capab_rings(9E), mac_ring_info(9E), mac_group_info(9E), ddi_intr_alloc(9F), mac_register(9S)
