man pages section 9: DDI and DKI Properties and Data Structures
Exit Print View
Updated: July 2014
usb_string_descr(9S)
Name
usb_string_descr - USB string descriptor
Synopsis
#include <sys/usb/usba.h>
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The usb_string_descr_t string descriptor defines the attributes of a string, including size and Unicode language ID. Other USB descriptors may have string descriptor index fields which refer to specific string descriptors retrieved as part of a device's configuration.
Please refer to Section 9.6.7 of the USB 2.0 specification. The USB 2.0 specification is available at www.usb.org.
A string descriptor has the following fields:
uint8_t       bLength                Size of this descriptor,
                                     in bytes.
uint8_t       bDescriptorType        Set to USB_DESCR_TYPE_STRING.
uint16_t      bString[1];            Variable length Unicode encoded
                                     string.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
PCI-based systems
Interface Stability
Committed
Availability
system/io/usb
See also
attributes(5), usb_get_alt_if(9F) , usb_get_cfg(9F), usb_get_dev_data (9F), usb_get_string_descr(9F), usb_parse_data(9F), usb_ctrl_request(9S)
Previous
Next
