Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Enable or Disable the Incremental Save Flag
Enable or Disable the Auto Save Flag
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
When you configure the default IP address, it is written to flash. This default IP address is used as the IP address of the default interface when the switch is restarted.
See Connect to SEFOS.
SEFOS-1# show nvram Default IP Address : 12.0.0.1 Default Subnet Mask : 255.255.0.0 ...
Note - VLAN 1 (the default VLAN) will have this IP address and subnet mask after the switch is restarted. A DHCP client is not supported.
