Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
This task shows the traffic flow in the RSTP configuration on SEFOS running on the switch targets. This task verifies whether a loop is present in the topology, if it is detected, and if the traffic is blocked for the alternate port.
See Switching Feature Topology for the topology of this task.
SEFOS-1# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 0 Port 0 [0] Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 0 Port 0 [0] Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:63:0f Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ---- Ex0/1 Designated Forwarding 2000 128 P2P Ex0/2 Designated Forwarding 2000 128 P2P Ex0/21 Designated Forwarding 2000 128 P2P Ex0/22 Designated Forwarding 2000 128 P2P ...
SEFOS-2# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 4000 Port Ex0/1 Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:6e:0e Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/1 Designated Forwarding 2000 128 P2P Ex0/21 root Forwarding 2000 128 P2P Ex0/22 Alternate Discarding 2000 128 P2P ...
# ping -s 20.0.0.30
Traffic is forwarded through the extreme-ethernet 0/21 port on SEFOS-1 to SEFOS-2 port 21.
SEFOS-2# configure terminal SEFOS-2(config)# int ext 0/21 SEFOS-2(config)# shut SEFOS-2(config)# exit SEFOS-2# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:69:0f Cost 4000 Port Ex0/1 Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:6e:0e Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/1 Designated Forwarding 2000 128 P2P Ex0/21 Disabled Forwarding 2000 128 P2P Ex0/22 root Forwarding 2000 128 P2P ...
# ping 20.0.0.30
Traffic should be forwarded through the extreme-ethernet 0/18 port on SEFOS-1. If RSTP is working, there will be a change in the port state.
