Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
Depending on how each server configures routes, you might need to add static routes with commands provided by the servers.
# route add 40.0.0.0 -netmask 255.255.255.0 10.0.0.201 # route add 20.0.0.0 -netmask 255.255.255.0 10.0.0.201
# route add -net 10.0.0.0 netmask 255.255.255.0 gw 40.0.0.200 # route add -net 20.0.0.0 netmask 255.255.255.0 gw 40.0.0.200
See Connect to SEFOS.
SEFOS-1# ping 40.0.0.200
SEFOS-1# ping 40.0.0.110
# ping -s 40.0.0.110
SEFOS-2# ping 10.0.0.201
SEFOS-2# ping 10.0.0.169
# ping 10.0.0.169
To reach host A from host B, packets must be routed between VLAN 40–VLAN 20 and VLAN 20–VLAN 10. With static routes configured, you can now test the routing functions with SEFOS.
