Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
-> create /SP/users/username fs_privilege=level
where:
username is the user name.
level is the privilege level (1 for read-only, 15 for full administrative).
For example:
-> create /SP/users/user15 fs_privilege=15 Creating user... Enter new password: ******** Enter new password again: ******** Created /SP/users/user15
-> show /SP/users/user15 /SP/users/user15 Targets: ssh Properties: role = o password = ***** fs_privilege = 15 Commands: cd set show ->
See Administering SEFOS.
