Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Enable or Disable the Incremental Save Flag
Enable or Disable the Auto Save Flag
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
This task describes how to configure the IP address for sending and receiving the packets.
See Connect to SEFOS.
SEFOS-1# configure terminal
SEFOS-1(config)# interface vlan 1
Note - You must shut down the interface before you can configure the IP address for that interface.
SEFOS-1(config-if)# shutdown
SEFOS-1(config-if)# ip address 12.0.0.1 255.0.0.0
SEFOS-1(config-if)# no shutdown
SEFOS-1(config)# end
SEFOS-1# show ip interface vlan1 is up, line protocol is up Internet Address is 12.0.0.1/8 Broadcast Address 12.255.255.255
