Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
This task describes how to configure and test the LA feature of SEFOS running on a switch target.
See Switching Feature Topology for the topology of this task.
SEFOS-1# configure terminal SEFOS-1(config)# set port-channel enable SEFOS-1(config)# interface port-channel 100 SEFOS-1(config-if)# no shutdown SEFOS-1(config-if)# exit SEFOS-1(config)# interface range extreme-ethernet 0/21-22 SEFOS-1(config-if)# no shutdown SEFOS-1(config-if)# channel-group 100 mode active SEFOS-1(config-if)# exit SEFOS-1(config)# vlan 101 SEFOS-1(config-vlan)# ports extreme-ethernet 0/1-2 port-channel 100 untagged extreme-ethernet 0/1-2 port-channel 100
SEFOS-1# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : Ex0/1,Ex0/2,po100 Untagged Ports : Ex0/1,Ex0/2,po100 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
SEFOS-1# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:69:ee Cost 0 Port 0 [0] Max age 20 Sec, forward delay 15 Sec Hello Time 2 Sec MST00 Spanning tree Protocol has been enabled MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:69:ee Max age is 20 sec, forward delay is 15 sec Hello Time is 2 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/1 Designated Forwarding 2000 128 P2P Ex0/2 Designated Forwarding 2000 128 P2P po100 Designated Forwarding 2000 128 P2P ...
There should not be any data loss during traffic forwarding.
SEFOS-1# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:69:ee Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) AD - Admin Down AU - Admin Up OD - Operative Down OU - Operative Up Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ------------------------------------------------------------------------- 100 Po100(P)[AU,OD] LACP Ex0/21(P),Ex0/22(P) ...
SEFOS-1# configure terminal SEFOS-1(config)# int ext 0/21 SEFOS-1(config-if)# shut SEFOS-1(config-if)# end SEFOS-1# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:69:ee Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) AD - Admin Down AU - Admin Up OD - Operative Down OU - Operative Up Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ----------------------------------------------------------------- 100 Po100(P)[AU,OD] LACP Ex0/21(D),Ex0/22(P) ...
LA was configured properly if traffic flows through the port channel group.
