Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Configuration Guide
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Basic SEFOS Topology
Default Configurations
Connect to SEFOS
Disconnect From SEFOS
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Configure the Default VLAN ID
Enable or Disable Trap Generation on an Interface
Configure Debug Logging
Configure ACL Filters
Configure QoS
Configure Port Mirroring
Configure Rate Limiting
Configuring Save Parameters
Managing Configuration Files
Save the Configuration to a File
Erase a Configuration File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Managing Log Files
View a System Log
Copy a System Log to a Remote Location
View Debug Logs
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configure Static Unicast Route Entries
Add Static Routes
Configuring Dynamic Routing
Configure RIP Dynamic Routing
Configure OSPF Dynamic Routing
Disabling Routing
Remove Static Routes
Disable RIP Dynamic Routing
Disable OSPF Dynamic Routing
Glossary
Index
Note - This procedure is best performed from the SER MGT port. If performed from the NET MGT port, you might lose connection to the SP during the process.
  1. Log in to the Oracle ILOM CLI.
    See Log In to the Oracle ILOM CLI.
  2. Change to the /SP/network directory.
    -> cd SP/network
  3. (Optional) Set the state of network management.
    -> set state = state
    where state is either enabled or disabled.
    Note - If you set the state to disabled, connections to the NET MGT port are lost.
  4. (Optional) Set the IP discovery mode.
    -> set pendingipdiscovery = mode
    where mode is either dhcp or static.
    Note - By default, the switch uses DHCP as the IP discovery mode.
  5. If you set the IP discovery mode to dhcp, go to Step 7.
  6. If you set the IP discovery mode to static, configure an externally accessible IP address on the switch.
    1. Set the pending service processor IP address.
      -> set pendingipaddress=IP_address
      Set 'pendingipaddress' to 'IP_address'
    2. Set the pending gateway IP address.
      -> set pendingipgateway=IP_address
      Set 'pendingipgateway' to 'IP_address'
    3. Set the pending netmask.
      -> set pendingipnetmask=netmask
      Set 'pendingipnetmask' to 'n.n.n.n'
  7. Verify the configuration information that you entered.
    The show command displays information about the switch, including its IP address.
    For example:
    -> show
     /SP/network
        Targets:
        Properties:
            type = Network Configuration
            commitpending = (Cannot show property)
            ipaddress = 10.7.59.97
            ipdiscovery = static
            ipgateway = 10.7.59.254
            ipnetmask = 255.255.255.0
            macaddress = 00:14:4f:6C:5D:E8
            pendingipaddress = 10.7.59.97
            pendingipdiscovery = static
            pendingipgateway = 10.7.59.254
            pendingipnetmask = 255.255.255.0
            state = enabled
        Commands:
            cd
            set
            show
  8. Commit the changes.
    -> set commitpending=true
    Set 'commitpending' to 'true'
    Note - When you set commitpending to true, connections to the NET MGT port might be lost. You must reestablish connection to the NET MGT port.
  9. When you are done, exit the switch Oracle ILOM.
    See Log Out of the Oracle ILOM CLI.
Related Information
