Go to main content
Oracle® Exadata Storage Server X5-2 Extreme Flash Service Manual
Exit Print View
Updated: January 2018
Exit BIOS Setup Utility
  1. Use the left and right arrow keys to navigate to the top-level Exit Menu.
  2. Use the up and down arrow keys to select the desired action.
  3. Press Enter to select the option.
    A confirmation dialog box appears.
    image:This figure shows the settings on the BIOS Save and Exit                         screen.
  4. In the confirmation dialog box, select Yes to proceed and exit the BIOS Setup Utility, or select No to stop the exit process.
    Note -  After modifying any BIOS settings and selecting Save Changes and Exit from the Exit Menu, the subsequent reboot might take longer than a typical reboot where no settings were modified. The additional delay is required to ensure that changes to the BIOS settings are synchronized with Oracle ILOM.
Related Information
